sanding
http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=1868
Author:  bob J [ Tue May 03, 2005 3:03 am ]
How fine -grits- do you sand tops and b/s before applying epoxy. How fine between coats of finish?
Do I need to use microbeads with System 3 for filling Macassar-if so what proportions?
Author:  Mattia Valente [ Tue May 03, 2005 3:13 am ]
Straight grained mahogany or EIR, and tops, P220 works fine, although P320 is a bit 'safer', perhaps. P400 is as far as I feel is necessary for a laquer finish guitar. If I'm oiling something, I go all the way to 1500 and steel wool.
Author:  LanceK [ Tue May 03, 2005 3:13 am ]
I sand to 320
Author:  tl507362 [ Tue May 03, 2005 3:28 am ]
220 is fine for epoxy and Laquer. Oil finish is different, you have to go much higher.
Author:  Harald Lane [ Tue May 03, 2005 3:33 am ]
Hi Bob!
Sand to P320, safest way to remove all scratches. I don?t recommend the use of microbeads with epoxy for porefilling, because this are small glassbubbles. I use instead an Thickener called Aerosil. Its easier to squegee it into the pores, the result is much better.
Author:  Michael Dale Payne [ Tue May 03, 2005 7:38 am ]
Bob, you asked about sanding tops before epoxy filling. I sand tops to P400. You do not need to fill tops such as spruce or cedar. just a seal coat of shellac is all that is needed on spruce and cedar tops.
I don't use microbeads except on very porous woods.
Author:  bob J [ Tue May 03, 2005 8:01 am ]
Thank you all. Very helpful.
